After the forum meeting at Benito's, we walked around a little bit and started looking at the Martha Washington Candy Co. building, located at 1412 W. Magnolia. It is an interesting building and Hometown By Handlebar has a post about the three big candy companies in Fort Worth. The last listing is for Martha Washington's Magnolia Ave. location. The link is to the post is: https://hometownbyha...ar.com/?p=10673
Martha Washington Candy Co. - 1412 W. Magnolia
#1
Posted 25 November 2022 - 10:53 PM
#2
Posted 26 November 2022 - 07:42 AM
Here's a few photos from our forum lunch walk and talk. I should have framed some of these wide angle shots better but took these on a whim.
Hometown By Handlebar's article included this photo but it was also posted on the main page oldftw referencing Lisa Helbing's Rare Photos which is still an active Flickr page worth checking out sometime. Hometown's caption reads: (Photo from Digital Research Library of Illinois History Journal.)
- TLA likes this
#3
Posted 06 November 2023 - 04:15 PM
I like those recessed steel entry doors and related transom windows and sidelites on the building's west side.
They look like they are made of weathered steel (aka COR-TEN).
Have a few questions for Forum members about steel doors/windows like these shown:
1. Can you clean/refinish/freshen up weathered steel/COR-TEN?
I assume those were installed in the late 90s or early 2000s. Definitely not bad looking at all, but, if it were my building, I'd want to try to make it crisper/fresher/cleaner, ideally without changing the weathered steel. Has anyone tried or know answer?
2. If you did decide to paint the weathered/ COR-TEN steel, would that even be possible with some sort of prep work before applying paint?
3. Are steel windows able to have good thermal performance compared with commonly used aluminum window systems? (assume: both are either thermally broken or not thermally broken so not an apples to oranges comparison in terms of thermal breaks).
(copied/pasted the image showing steel doors, transom windows and sidelites from previous post):
- Stadtplan likes this
#4
Posted 07 November 2023 - 02:05 PM
I remember my grandmother talking about this candy company.
#5
Posted 07 November 2023 - 02:20 PM
Those doors were installed in the 1990's? I would have guessed way older than that.
I wouldn't touch the metal with any cleaner but you could certainly use something to clean the façade and brighten it up.
I wonder if Cleansol BC would work for the masonry surfaces? https://www.eacochem...s/cleansol.html
#6
Posted 08 November 2023 - 06:42 AM
The whole unit needs to be sanded by hand (just to rough up the surface, not trying to get to bare metal), then wipe it down with lacquer thinner. After that its ready for paint. I would probably use All Surface Enamel Oil or Emerald Urethane to paint it. Both of those are Sherwin Williams products and come in any color and multiple sheens.
- txbornviking likes this
Also tagged with one or more of these keywords: Near Southside
Near Southside
Projects and New Construction →
Residential →
Twilight Lofts: 299 Units, 7 Story w/Parking GarageStarted by Austin55, 02 Jul 2020 ![]() |
Near Southside
Residential →
The Vickery at Near Southside (W Vickery St. and Hemphill St.)Started by Stadtplan, 22 Feb 2022 ![]() |
Near Southside
Residential →
Magnolia HighlineStarted by Austin55, 15 Aug 2020 ![]() |
Fairmount
Commercial →
Mixed-use Development at 701 W Magnolia (behind Shinuku)Started by Austin55, 29 Feb 2020 ![]() |
Near Southside
Residential →
3rd Hudgins project in Near SouthsideStarted by Austin55, 28 Feb 2020 ![]() |
